Okay, I already did. I am using an ATMega328P, how do I make the relationship in the programming so that 2.5 meters correspond to 10mV? I tried to make the relationship but I get 10mV / 2mSo the maximum sensor output is just 40mV?
So connect a voltage source of 40mV to SN-1 in your picture.
That will give 0 to 40mV at the AD0 output for the potentiometer going from 0% to 100%.
Hey, I tried with this.hi Cam,
Post your Arduino sketch.
E
#define SN1 A0
#define SN2 A1
float vRef = 0;
int nivelSN1;
int voltajeSN1;
void setup()
Serial.begin(9600);
void loop()
vRef = voltaje_Ref();
nivelSN1 = analogRead(SN1);
voltajeSN1 = Escalizar(nivelSN1, 0, 8, 0, 40);
nivelSN1 = Escalizar(voltajeSN1, 0, 40, 0, 10);
Serial.print(voltajeSN1); Serial.println(nivelSN1);
delay(500);
float Escalizar(float variable, float in_min, float in_max, float out_min, float out_max)
return (variable - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Hi,I am not using the 5V reference,
Okay, I will try adding a amplifier, but, should I use 5V or 40mV input to the potentiometer?hi C,
If you are using the internal 5V ref for the ADC, which give 1023 counts for 5V input, but for 0.04V
input to the ADC that will only be 1023(0.04/5) = 8 Counts, much to coarse to resolve to 2.5mtr.
E
You should add a OPA amplifier from the pot to the ADC input.
I am using 40mV as @crutschow saidHi,
So what ADC reference voltage value are you using.?
E
Thanks for the help, I did it this way, will it be okay? I don't use the map command because I need the 2.5 meters in the output, if I use map it throws me as an integer type and I only get a 2.hi,
I would use the internal 5Vref and supply the pot with 5V.
[the same 5V as the Arduino]
In the sketch use the MAP command.
E
example.
Change the 255 to 100, then some maths to make it 10.0 mtrs
#define SN1 A0
#define SN2 A1
float vRef = 0;
float nivelSN1;
float voltajeSN1;
void setup()
Serial.begin(9600);
void loop()
voltajeSN1 = Escalizar(nivelSN1, 0, 1023, 0, (vRef*8));
nivelSN1 = Escalizar(voltajeSN1, 0, (vRef*8), 0, 10);
Serial.print("V: "); Serial.print(voltajeSN1); Serial.println(" mV");
Serial.print("Distance: "); Serial.print(nivelSN1); Serial.println(" meters");
delay(500);
float voltaje_Ref()
long result;
float respuesta;
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
delay(2);
ADCSRA |= _BV(ADSC);
while (bit_is_set(ADCSRA, ADSC));
result = ADCL;
result |= ADCH << 8;
result = (1125300L / result);
respuesta = result / 1000.0;
return respuesta;
Thanks a lot! you are the best <3hi C,
The result you have posted looks OK.
Are you able to read from 0m thru 10.0mtrs in the 2.5mtr steps OK.
E
BTW:
For future reference you could MAP the 1023 count to 1000 and use maths to give 0.0m the 10.0mtr
// Water Height Camiloo 21-08-2021
const int analogInPin = A0;
int ADC0in = 0;
float Water= 0;
void setup() {
Serial.begin(9600);
void loop() {
ADC0in = analogRead(analogInPin);// read the 10k pot voltage
Water = map(ADC0in, 0, 1023, 0, 100); // Map 1023 to 100 units
Water= ((Water/10)); // divide by 10 for decimal
Serial.print("Water= ");
Serial.print(Water,1); //print to One decimal place
Serial.println("mtr");
delay(1000);
by Jake Hertz
by Jake Hertz
by Jake Hertz
