Electrode shape for capacitive water level sensor
rowan.bradley
Joined Jul 26, 2020
I am trying to design an automatic water filling system for my coffee machine. I need to design and make two non-contact non-immersion level sensors for the water tank. Ideally these should use electrodes on a thin printed circuit mounted just behind the tank. It needs to detect two levels:
  1. A low level "turn the water on" sensor
  2. A high level "turn the water off" sensor
What is the best shape to make these electrodes?
where green is earth, red is live. Or something else.
I have not determined what circuit to use for the detector yet. I have a schematic for a RC oscillator design. But if you have a better idea, please describe.
Thank you - Rowan
wayneh
Joined Sep 9, 2010
18,172
... two non-contact non-immersion level sensors...
How are you thinking either configuration can sense the water level without being immersed? An optical or ultrasonic sensor might be better. A float switch is effective but I can see why you'd prefer no moving parts for this application. You may want to also consider a secondary, backup system to prevent overfilling. Failing to fill properly after going empty is a nuisance, but a runaway fill is a lawsuit.
Ya’akov
Joined Jan 27, 2019
10,312
This TI app note might be worth skimming.
boostbuck
Joined Oct 5, 2017
1,065
I've long used 300 ohm TV twin flat ribbon to make make tank depth sensors. Immersed but insulated from the liquid, measuring the capacitance change as the liquid level changes.
