Wiring an electrode
sahmed7975
Joined Feb 22, 2022
I'm setting up a hollow cathode discharge for spectroscopy purposes and I need to conduct from a wire to a rod, and then from a rod to the electrode.
Can I simply wrap the wire around the rod, and place the electrode on top of the rod in contact?
Delta Prime
Joined Nov 15, 2019
1,311
Hello there welcome to AAC! :)in order to avoid confusion. Spectroscopy in it's basic form is the study of how light Interacts with molecules. Therefore clarification is needed .May I ask what are you trying to achieve? The type of electrode will depend on the material used and depending on your application.
