LED Reverse Voltage VR = 5 V design help needed ?
ronsimpson
Joined Oct 7, 2019
4,690
In your circuit there will never be any reverse voltage. Don't worry about it.
----edited----
If you put a 6V power supply across the diode backwards, so no light, then the diode might get hot and die.
mishra87
Joined Jan 17, 2016
1,063
----edited----
I assume when LED is off only LED anode see 6V since 6V is dc source not AC.
So no damage at all.
