Where, exactly, in that data sheet do you see minimum and maximum power of 250 mW and 350 mW?i want to operate them at their max current. from what i see on the sheets their min is 250mW and max 350mW so yeah sorrry
it would be 1400ma.
i got it from here https://www.mouser.com/ds/2/90/XLampXPE-221789.pdf
for the XPEFAR-L1-0000-00701 cobs
For the far red LED, the maximum current is 1000 mA. If the LEDs are in series, then the SAME 1000 mA that flow in one will flow in all of them. The data sheet only gives a typical forward voltage of 2.25 V for this case, but based on the other data you can probably expect the actual voltage to be up to 500 mV above or below this, so perhaps as much as 11 V and as low as 7 V, but more likely somewhere between 8 V and 10 V.
As has been pointed out several times, it is generally NOT a good idea to operate LEDs at their max current. But you seem insistent on doing so. Just don't be surprised if they don't last as long as you think they should, particularly if you don't heat sink them very well.
A 12 V DC supply that can deliver a minimum of 1 A should work. You'd be better off with one that can deliver 2 A because it will run cooler when delivering 1 A than a 1 A unit will when being run at its max. A 15 V DC supply will let you control the current more tightly, but will also waste more energy.
