KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
Not sure I believe that.Also, no LED will be blindingly bright at 2mA.
OK, testing with a green LED (the most subjectively bright) at 2mA it's bright but I can look at it. It's not blinding. It's probably too bright for an indicator but its not painful or even uncomfortable. With a white LED at 2mA, it's a bit less. Bright, not blinding.Not sure I believe that.
There are some high efficiency white leds that operate around 2mA instead of 20 mA.
I wasn't saying LEDs don't emit light at 2mA. In fact, I measured sub-μA current for an illuminating white LED in #16 . I was saying that LEDs don't get blindingly bright at 2mA.Then the LED illuminates so much that I actually can't look at it.
I mentioned it?Nobody mentioned the viewing angle of an LED.
Cheap LEDs are dim ones in a case that focuses the light beam into a fairly bright but narrow angle.
Modern LEDs are very bright but with a wide viewing angle. A few modern LEDs are in a case that focuses the light beam into a blindingly super-bright narrow angle like a laser beam.
Also, the light level at 2mA is not low on-axis to a narrow angle LED and surely the discomfort is subjective so it might be a reasonable description of his experience at 2mA.
Any way, this is a total diversion from the thread.I mentioned it?
I agree that "blinding" is exaggerated, but the highly focused ones, up close on your bench, can be pretty darn bright if your eye is on-axis with the beam.Also, no LED will be blindingly bright at 2mA.
Those LEDs are emitting light but until you drive them to their rated current (probably 20mA) you are only measuring something incidental: when the begin to light. They have ratings for forward voltage, current, and light output which are only valid at the current rating.I have been testing a setup with a voltage supply I had laying around and it supplies with 24.50 volt.
I put 9 white LED's in seriel with a 3,265 ohm resistor.
Then I started measuring.
I measured the forward voltage over a single LED to 2.605 volt
The forward voltage over the resistor to 1.168 volt
The total forward current measured 0.34mA (see picture)View attachment 236929
What should I conclude of this setup? Does it really use that little power?
Voltage times current.So how can I measure its actual power consumption?
i forgot that I was going to leave this thread. I have no idea what the TS is trying to do so I should just ignore this.Voltage times current.
Off topic but this reminds me of a circuit I posted many years ago where I used a white LED and describing it as "easily visible at 1ma". Well this guy replied and remarked that my circuit was irresponsible because I wasn't operating the LED at 20ma.
I replied and said there was no law that you have to operate a LED always at 20ma. His reply was "yes there is, it's called Ohms Law". At that point I threw my hands up and walked away.
The voltage is 2.6 volt and the current is measured to 0.34 mA.Voltage times current.
Are you still passing back and forth in an alternate reality?i forgot that I was going to leave this thread.
