LED lights
Firefox21
Joined Apr 9, 2022
I'm repairing a 1987 Honda radio and I'm in need of LED lights for the back light does anybody know where a could get these lights?
There green if anyone is wondering.
MrSalts
Joined Apr 2, 2020
2,767
It seems unlikely that three LEDs fail - maybe the driver is dead. Try replacing the. With any LED to see if you can get them to power up.
Firefox21
Joined Apr 9, 2022
Ok thank you. the ones in the picture have a short somewhere that I have to find. When I lightly push on the radio face it lights back up. But I will use your advise to test the three under the tune button as they don't light up at all. Again thank you.
MrSalts
Joined Apr 2, 2020
2,767
Otherwise, measure the length and width and height off of the PCB. Then look up "indicator LED" on Digikey.com (or any other electronics component distributor. You should be able to select color, size, etc until you find one that works for you.
paulktreg
Joined Jun 2, 2008
851
If it lights up when you push the display it's unlikely you have a short. It sounds like something is open so check the quality of the soldering you may have a cracked joint?
