LED Lights - Power Supply / Battery
bertus
Joined Apr 5, 2008
22,931
Here is a little explanation how they made the values:
Resistance value
As for the standard resistance value, the values used can be divided like a logarithm.
For example, in the case of E3, The values [1], [2.2], [4.7] and [10] are used. They divide 10 into three, like a logarithm.
In the case of E6 : [1], [1.5], [2.2], [3.3], [4.7], [6.8], [10].
In the case of E12 : [1], [1.2], [1.5], [1.8], [2.2], [2.7], [3.3], [3.9], [4.7], [5.6], [6.8], [8.2], [10].
It is because of this that the resistance value is seen at a glance to be a discrete value.
The resistance value is displayed using the color code( the colored bars/the colored stripes ), because the average resistor is too small to have the value printed on it with numbers.
You had better learn the color code, because almost all resistors of 1/2W or less use the color code to display the resistance value.
This info comes from this page:
http://www.piclist.com/images/www/hobby_elec/e_resistor.htm
Bertus
THRobinson
Joined Jun 7, 2018
82
LED's from Amazon super bright and look great.
Ended up going to the dollarstore, buying cheap paint brushes and using the clear acrylic handles. Put them in a drill and took scotchbrite pad to them to frost them up. Used the wires from inside a CAT5 network cable, which was perfect because 8 wires in pairs. Ended up using 3xAAA regular batteries, not rechargeable, and the battery clip barely fit inside. On/off switch hidden on the frame. Soldered up a small circuit board with the resistors on it. Came out really nice.
jiggermole
Joined Jul 29, 2016
185
That looks really good!
Geeking out about leds is fun. There are some very scary led COBs from china if you want to blind the neighbors if you're looking for a followup project.
