LED Lights on Guitar causing hum
ElectricSpidey
Joined Dec 2, 2017
3,374
The low pass filter is definitely worth looking into, as this avoids the problems associated with using only a capacitor, and will be simple to install. (x 3 of course)
There is even a tutorial on this very subject on this site.
heatseeker19
Joined Mar 15, 2018
10
So you suggest 3 lowpass filters, all bridging the circuit and the led strip? Nothing on the V+ right?
ElectricSpidey
Joined Dec 2, 2017
3,374
Yes, one for each color placed in between the controller output and the LEDs. (see post #8)
I'm not sure what you mean by "nothing on the V+" The filter inserts between the negative outputs from the controller and goes to V+. (the inductor is in series with the LEDs)
I would also try to get the controller as far from the guitar as possible (within reason) because there will still be some unfiltered RFI. Perhaps you could place that bad boy in a metal box along with the filters.
And for more help search for PWM to Analog. (AKA DAC...digital to analog)
Getting the component values correct will be your biggest challenge.
