We need a from 60mA to 200mA. I need to limit the current because in the power led is a led driver thing that adjust the light intensity by increasing or decreasing the current.What current does the LED need and why do you think you need to externally limit the currrnt?
Can you clarify what you mean by this? Also, providing a link to the actual LED will be helpful. Is it an LED or an LED light or bulb?because in the power led is a led driver thing that adjust the light intensity by increasing or decreasing the current.
here is a link to the led light: https://www.sealite.com/1-5nm-stand-alone-marine-lantern/Can you clarify what you mean by this? Also, providing a link to the actual LED will be helpful. Is it an LED or an LED light or bulb?
That IC seems to be simply the wrong choice for the load. On the other hand, it does include an REXT pin which allows selection of current up to 350mA—did you miss that?here is a link to the led light: https://www.sealite.com/1-5nm-stand-alone-marine-lantern/
I want to design a pcb so I can choose the current through the lamp. I tried this led driver (https://be.farnell.com/diodes-inc/bcr421uw6-7/led-driver-aec-q101-linear-sot/dp/3127238) but it gots realy hot and gives a current from 10mA.
Why do you think you need a LED driver for this item? Have you read the data sheet (below)?Hello,
I am looking for a led driver to limit the current to a 12V led. Now I have a 12V battery that powers the led. The most led drivers I found is the current limit to not more than 10mA. How do I realize this?
Thanks in advance
