- Joined Jan 23, 2018
- 28,385
Evidently I do not understand the details of how whatever was to be achieved will achieve the TS goals.
Agreed, but to get that you need interference from coherence. When you split the coherence into two light sources, each source must maintain wavelength, otherwise the interference from phase shifts as the sources change. LED's will change wavelength as it warms and while being used. So the challenge there is how you can control the two sourecs, or account for their dynamics. Then, even if each "identical" spec LED was staked on wavelength, they will not be the exact same wavelength.The TS just wants to see the ~10Hz beat frequency of the flashing, not of the differences between the ~333THz light sources.
thank you,@Dr John: it seems that your autocorrect has not been ware of LEDs. AND, only the cheap ones are that cheap.
