Led circuit design
Sensacell
Joined Jun 19, 2012
3,789
D11 halves the power dissipation, but it's reverse voltage rating is too low for the situation.
The circuit will work fine without D11, but the resistor will get twice as hot.
moonlystar1111
Joined Feb 1, 2024
106
Isn't it's going to remain same if d12 is removed along with d11? What is the purpose of adding 2 diodes then?
28,626
D11 is intended to provide only a positive voltage to the LED. Diode D12 is intended to prevent reverse voltage destruction of the LED. Unfortunately the circuit will fail and probably all three diodes will be destroyed because the supplied voltage exceeds the allowable reverse voltage of the diodes.
moonlystar1111
Joined Feb 1, 2024
106
Yeah got your point. But in actually led and diodes of different make will be used. I have only demonstrated it here for an idea. It will be near load and not near supply.
Also will led glow if load is not connected?
28,626
I calculate the LED current as about 25 mA, a bit above the 20 mA rating. The LED illumination is not related to the load off to the right side of the drawing. That is a parallel connected circuit, they are totally independent.
