Sorry for not giving the exact model name. Its 270-AB which hass a thermal resistance Thermal Resistance: 70°C @ 4W . Does this mean it allows the IC to heat upto 70 degree per watt for a 4W load?If your transformer is 24VAC then its peak voltage is 34V and its output is +32V minus a few volts of ripple. Maybe +29VDC.
You ASSUME the LED voltage to be 4V but each brand and color is different. The minimum voltage might be 3.5V and four in series use 14V.
The LM317 drops 1.25V across its current-sensing resistor so it has across it 29V - 14V - 1.25V= 13.75V. Therefore its maximum heat dissipation is 13.75V x 350mA= 4.8W.
The tiny heatsinks you selected allow the case of the LM317 to heat 55 degrees C for each Watt so the case will be 55 degrees x 4.8W= 264 degrees C and the chip of the LM317 will be much higher than that. The temperature of the ambient air adds to the heating. The maximum allowed chip temperature is only 125 degrees C.
Therefore the heatsinks are much too small for your very high rectified and filtered voltage.
The LEDs also need heatsinks since each LED dissipates a maximum of 4.5V x 350mA= 1.58W. A 3.5V LED dissipates 1.2W of heat. If the heatsinks are in an enclosure then the heating is concentrated and the enclosure becomes an oven.
EDIT: I calculated with the tiny surface-mount heatsinks on the first page of the datasheet. The heatsinks for TO-220 are much bigger and cool better. But maybe not enough.
Again, 270-ABYes those are for TO-220, but the question is if the are large enough to keep the lm317 cool. So to get the worst case, lets assume the LEDs will have Vf a little lower than you thought, so you will end up with 6V from in to out of the lm317, multiply this with 350mA and you get 2.1W dissipation.
Thermal resistance from junction to the cooling tab is 5 K/W, so you will have 10K more inside the chip than outside. Maximal junction temperature is 150°C, so lets stay conservative and aim for 100°C max on the cooling tab. Now lets assume the ambient temperature is 50°C, so you need to dissipate 2.1W over 50K, so the heatsink must have 23K/W or better thermal resistance, and that minus 1 or 2 K/W for the tab-to-heatsink junction. With forced cooling you could use smaller heatsinks.
I just noticed the PDF with the heatsinks hase more than one pageWhich exact type did zou want to use?
Looking at that graph that figure 70°C @ 4W probably means a rise of 17.5°C above ambient temperature for each 1W and the graph seems to agree
I'll try to get a better heat sinkThe temperature rise at the surface of the heatsink is 70 degrees C for a dissipation of 4W. So for 1W the temperature rise is 17.5W.
For a dissipation of 4.8W then the temperature rise for the heatsink is 17.5 degrees x 4.8W= 84 degrees C.
The temperature rise from the chip to the case of the regulator is 4 degrees C for each Watt so its total temperature rise is 4 x 4.8W= 19.2 degrees.
The ambient might be 30 degrees C.
Then the chip temperature is 84 + 19.2 + 30= 133.2 degrees C which is TOO HOT!
The max allowed temperature of the operating chip is only 125 degrees C so the little heatsink is too small.
Sorry about the link. I've noticed a typo in the form of a \ at the end that does not occur in links.Your link to the Avago LED does not work so we don't know its spec's. Then we don't know if a 16V transformer produces not enough or too much voltage. If you post its part number then we can look up its datasheet.
The transformer must have a VA spec which is the amount of power it must transfer to the entire circuit, not just to the LEDs. The bridge rectifier, the LM317 regulators and the current-sensing resistors also heat with some power from the transformer. It is simple to calculate the current rating needed of the transformer when the needed VA rating is calculated.
Your new heatsink is even smaller that the previous one so it will probably cause the LM317 regulators to overheat.
Without having the spec's for the LEDs then we don't know the size of a heatsink they need.
You show an oscilloscope trace of pulsing DC (from the bridge rectifier?) that averages about +9.5V. It is a 50Hz sine-wave instead of the 100Hz triangle-wave expected from a bridge rectifier so there is something wrong with your power supply.
From searching the internet and watching tutorials, I've found that Cree LEDs are comparatively reliable and cost effective.The tiny LEDs are "surface-mount" style which needs a heatsink. But they are too small to bolt to a heatsink so their metal tab is soldered to a large-area of copper on a pcb.
It will be very difficult to solder, usually a machine solders it.
You should use "normal" STAR LEDs that are bolted to a "normal" heatsink.
You should select STAR LEDs that do not need to be operating at their absolute maximum allowed continuous current. Most STAR LEDs have 700mA as their absolute maximum allowed continuous current.
The red or amber LEDs have a voltage that is much less than the blue or green LEDs so the LM317 driving the red or amber LEDs will get VERY hot unless more red or amber LEDs are connected in series or unless a resistor is used in series to share the heat.
Your soldering iron might destroy the tiny surface-mount LEDs.Attach the SMD LED to a thermal substrate(Heat sink pad) using solder paste and heat it using heat gun.
If I do not have a heat gun, can I place the solder iron near the SMD device so that the solder melts off, then place it on the heat sink pad which already had sufficient solder paste?
I do not know how long the LED with a soldered substrate heats then is too hot.Would I need a heat sink after the thermal substrate? I'm only using the LED for a little while (About 10 seconds) in a single stretch, so will that be a problem?
Heat sinks for power transistors might work and are very cheap.If I need another heat sink, what heat sink should I select? I'd like it to be the lowest price possible (I am a student, and this project is only for demonstration, not actual use) to achieve its purpose. I've heard of MCPCBs and aluminium heat sinks. Which would be less expensive? Can someone link me to an adequate heat sink for this in element14 or mouser?
If heat sinks are close together then a fan is needed.I need to place these LEDs as close as possible to each other. What would be the minimum spacing? Please consider this when suggesting heat sinks.
I have never seen a metal core pcb and you probably also have not and will never see one. Aluminum heat sinks for power transistors are very cheap in North America.I understand there are MCPCB heat sinks, Aluminium heat sinks etc... which one would be of a lower cost? Can I use a single large heat sink for multiple LEDs?
