u're goinf the wrong way. you are providing with vibration to the plates which is dangerous. please dont do that. i suggest you to work on some kind of electronic device.Ahh.. I didnt even think the motion could cause the sediment to create a short. hrmm.
That could definitely cause a heating problem.
I built a little rocker board today. I connected a piece of pvc to a .75" plywood circle about 1' dia. The 1.5" pvc has a 2" pvc sleeve on it to allow a smoother movement. I can adjust the cam along the radius to change the rocking motion. As well as changing the distance from the hinge gives a pretty good range of motion. Using plywood rather than stock board, the flexibility also adds a gentleness to the motion. Like a spring board.
I may just pulse this one rather than add the charger to it as well.
Any idea at what temperature the sulfation crystals melt/dissolve in the bath?
I was thinking if the sulfates were dissolved in the mixture, the re-combination would be more effective.
