Originally posted by Kenny@Nov 29 2004, 07:21 PM
I have a cheap LCD labeled "PWB50240 OPTREX IM50240 (MADE IN JAPAN)" that uses only one HD44100H controller. I don't have any info about it. The weird thing is that the LCD has only 10 lines instead of the standard 14. Can anyone help me?
[post=3859]Quoted post[/post]
Anyway, it will be easier if you buy another 2x16 with 14 or 16 lines with it, and that will make you go ahead with what you wantOriginally posted by Kenny@Dec 10 2004, 06:46 AM
>>Is this the 40x4 character matrix LCD?
No. It seems a 2x16.
>>Maybe that LCD is restricted to have only a 4 Bit interface that is why.
I have been thinking the same, but how can I know it.
For these days I don´t have enough time, but I am beggining to check the 66100H datasheet (44100H replacement). I have made various web searchs and nobody seems to have info. In the only real search hit where is referenced this LCD is in a forum where there is someone that have the same problem that me: There is no info about it.
How is possible that exists a garbage electronic components around it (made by Optrex Japan) without any bit of info.
Thanks
[post=4044]Quoted post[/post]
Attached is word doc with pinout, shift register organization and sample c code for PIC.I have a cheap LCD labeled "PWB50240 OPTREX IM50240 (MADE IN JAPAN)" that uses only one HD44100H controller. I don't have any info about it. The weird thing is that the LCD has only 10 lines instead of the standard 14. Can anyone help me?
