Hi All, I'm new to these boards, but i plan on sticking around and helping where possible, so please go easy on me to begin with. I have what i think is a simple problem to solve. I have a background as an electrician and have designed many control circuits for electrical projects which have a 24v control circuit and 240+ power circuit. The standard system i use to turn it on is a momentary NO switch through a relay, holding the coil in, and power on, one the momentary switch has been pressed. Turning off via a momentary NC switch cutting power to the relay coil. This works fine and hasn't caused any problems. A schematic is shown below. SW1 turns on the circut, SW2 off. when coil is energised, contacts 1 and 3 are joined applying constant power to coil.
What i want to do is make this same circuit using transistors as they are considerably cheaper and smaller than relays. I had a theory on a simple circuit but upon breadboarding it i didn't work; my understanding of transistors is limited.
Obviously this circuit can only be used in the control circuits and relays will be needed to switch any 240v power circuits. Any help would be greatly appreciated.
Thanks,
Ryan
Thanks,
Ryan
