Latch/Unlatch Test Jig design for a 12V, 3A solenoid
Bharath S
Joined Dec 27, 2019
I need to design a test jig for a 12V, 3A solenoid which does the following:
1. Latch during +ve voltage supply. But the input +ve voltage should be only for 300 ms
2. Unlatch during -ve voltage supply. Again, the -ve voltage should not be for more than 300 ms.
This is the first design project that I'm doing, so I would really appreciate it if somebody can help me the components which will be needed(with P/N if you have) and also a circuit diagram.
Thank you
ericgibbs
Joined Jan 29, 2010
21,572
hi BS,
Welcome to AAC.
Your description is not very clear.
eg: is +ve a 300mS pulse to the relay coil and do you mean -ve voltage or 0v.?
It is possible a 'latching' type relay would do want you want, need more information.
Post a sketch showing the circuit idea and the pulse waveforms.
E
