Laser driver
Zun
Joined Aug 6, 2017
72
Hello, i want to drive my 10 nm green laser diod,input 4v,output ,2v 393 MA, what suggest diagram for it,thank you
ericgibbs
Joined Jan 29, 2010
21,439
hi Zun,
Do you want to pulse the laser diode or continuous,?
I think you have a typo on the 10nm value, typically 532nm.
E
Zun
Joined Aug 6, 2017
72
hi Zun,
E
Yes Continue laser, typo, 10 mw,
OSRAM 10mw PLT5 510 515nm Green Laser Diode
Zun
Joined Aug 6, 2017
72
Ok
hi Z,
Look thru this link for laser Constant Current drivers.
Lets us know which you choose and we can discuss it.
E
https://www.google.com/search?q=las...PltrbAhUUWsAKHXZaBNAQsAQI0wI&biw=1328&bih=868
This is a simple circuit.
When this circuit
hi Z,
E
I just try this circuit, input 4.5 v, just got 280 MA, when input 6.5 v ,I got 400 MA, but this, I need 4.5 v only, for my friend level laser modifications,
https://laserpointerforums.com/atta...ll-3v-driver-info-request-driver-positive.jpg
How this
Bordodynov
Joined May 20, 2015
3,431
The operating voltage on this laser can reach 7 volts (see datasheet). The driver needs a supply voltage of 7.5 - 8 volts. The Chinese make a step-up converter (charge pump) to power the laser driver (for the finished laser modules). There is another system. This is when the current generator is fed by an infrared laser and nonlinear optics convert the IR into a green light. In this case, 3 volts is enough.
Zun
Joined Aug 6, 2017
72
I just buy a diod only, true laser diod
For fix to my level laser housing
ericgibbs
Joined Jan 29, 2010
21,439
hi Zun,
The laser diode datasheet says operating current typical 60mA, 100mA max at 5.5v to 7v.
I would modify the simple circuit in post #5 to give 60mA at 6.5v
E
