Hiya, me again!
I've got a laser level which has stopped working, i took the main board out and there was a S8550 transistor that when the board was powered, was running at a toasty 220c.
It looks like either that has caused the laser diode driver to fail or vice versa, there is what I think might be a TVS that has failed on the PCB for the laser diode.
The markings from what I can see are either: SGC or S6C
The measurements of the component are:
H: 1.95mm
W: 1.9mm
L: 3.4mm
Length is not including solder and are approximate as I'm only using some cheap digital calipers.
I think this is a 1SMA28ACAT3G and I think that makes sense given it's positioning on the diode driver, but I'm not certain.
I've attached some photos, if anyone who's better at this than I am could give me their two penneth I'd appreciate it.
H: 1.95mm
W: 1.9mm
L: 3.4mm
