Large offset at output of follower opamp
Maminej
Joined Dec 31, 2011
5
Hello Everyone,
I have been trying to get a voltage follower to work for my application with no success.
I am using voltage followers in my design in several places and have no problems, but for this particular configuration my input voltage is very small ( 0.17 mV) and I am measuring 60 to 80mV output voltage at the output.
I read several papers and tried different approaches ( on this website and other ) but I can't seem to find a way around this issue.
My input voltage comes from a thermistor linearizing resistor network and will range from 0.17 ( T=25C) to 0.28mV ( T=50C)
Here is my initial setup :
I started with the TLV2370 .which has an input offset voltage in the order to ~2mV. I though that was my problem so I switched to an LTC2050 ( have it handy) with input offset voltage is in the uV range.
I still measure about the same output voltage of around 60 to 80mV.
I tried this setup ( Although some member of this forum disapproved in some posts ) and it didn't help. I was able to increase the offset but not decrease it.
I also tried matching the feedback resistor with an input resistor (here) ( 1K trying to limit the input bias current ) but still measure the same output voltage of 60mV when the the input is 0.16 mV.
I do not want to use an opamp with a nulling input and endup with a pot on the board.
I think I am missing something and can;t figure it out by myself. I hope someone smarter can help me out here.
AJ
Ylli
Joined Nov 13, 2015
1,092
What are you using for +V and -V?
You could try adding a 1K resistor in series with the non-inverting input. Then change R7 to 1K also.
The source impedance from your resistive network (top of R8) is very low (<10 ohms), do you really need a buffer on that line?
Maminej
Joined Dec 31, 2011
5
Thanks for your reply
I am using 3.3V for V+ and an AGND for V-
I tried what you suggested in an effort to limit the biased in the nin inverted input and changed the feedback resistor to 1k as well but I still got the same output voltage level.
Regarding your question on the need for a buffer: my intension in to feed this signal as a bias voltage to a non inverting opamp that amplifies an IR detector signal ( thermopile) in order to perform some sort of ambient temperature compensation. This IR sensor is mounted on a surface that heats up and its temperature varie from 25 to 50C and comes with an embedded thermistor.
I was trying to avoid connecting the resistor network in series with R1 (replaces VREF in below schematic) because I think that it will also make my gain change with temperature. ( becauss of the thermistor)
I want the offset to change with Temp. and gain to remain constant.
ebeowulf17
Joined Aug 12, 2014
3,307
I might be misunderstanding these specs (happens more often than I'd like to admit,) but it looks like the lowest output it's capable of can easily be 100-150mV above ground in the 2.7-5V Vdd range, and is "typically" 50-100mV in that range.
Maminej
Joined Dec 31, 2011
5
Probably going to need at least a couple of -volts on that -V pin. You are trying to operate with input and output right at the rail.
You are right.
I used a lab power supply and fed +/- 3.3v to that opamp and the follower is working now.
I don;t have anegative rail on my board at the moment. Although it is not impossible to add one, I still have some space limitation on it.
Can you please suggest a way of providing a -v rail to the opamp.
It looks to me like Inverting DC/DC Converters are switching regulators and will require an inductance , a relatively large cap and a diode at the output. I looked at the LT1617 datasheet and few similar products.
Your suggestions are greatly appreciated
