Amplifying and filtering small AC signal with large DC offset
dmccric
Joined Apr 2, 2019
I am trying to extract a small AC signal (~50mV Pk - Pk) from an Instrumentation Amplifier using a Single Supply voltage (+5V) and I want to get rid of the DC Offset (+2.5V) so I can amplify and filter the AC part (1kHz mid frequency). I want to produce a clean signal of around 700mV Pk - Pk.
Is it possible to remove the DC Part and then filter the AC signal? I can do this with a dual rail supply but this adds further noise.
The circuit is attached.
ericgibbs
Joined Jan 29, 2010
21,591
hi dm,
Welcome to AAC.
It is possible to AC couple the output from the IA amplifier.
What are the range of frequencies required.?
E
EDIT:
This similar circuit shows the method to remove the DC offset.
dmccric
Joined Apr 2, 2019
I think I'm going to have to reduce the frequency range to 30Hz to 250Hz. Interesting circuit, applying the mid point to the positive input terminal.
I am not getting the same output yet but I am doubling checking my circuit now.
Thank you.
