Laptop charger / power supply
aj911
Joined Jul 14, 2017
7
Can someone please assist?
My Asus charger initially outputs specified voltage, but within a few seconds gradually drops to zero. There are no physical clues... What components should I check?
dendad
Joined Feb 20, 2016
4,641
The capacitors are a likely suspect.
But, remember, be careful as there are lethal voltages inside that black box.
Make sure it is unplugged and the caps are discharged before you poke around in it.
gerty
Joined Aug 30, 2007
1,305
Every one of those I worked on had a bad connection on the DC connector where the cable was bent repeatedly..
