Thank you very much for your quick reply.Preferably leave the inline suppressor on unless you have no choice.
Max.
Thank you very much Wayneh for your reply..I doubt you'll ever know the difference but I'd leave in on if I could. It can still do its original function if it's still there.
Thank you for help it is much appreciated...I would bet that if he had no choice but to cut off the suppressor he could probably strip it down to the bare toroidal core halves and just reattach it further up the line. Use tape to hold it together and in place. OR if you can find shrink sleeving that will accommodate that large an item and still shrink down sufficiently - - - .
Ok Dave, Thank you very much..Thats the Negative lead, and it's used as a Screen.
Its best to leave the ferrite collar on unless its in the way.Thank you very much for your quick reply.
John...![]()
