None of the parts are critical. It should work with whatever you have available.
Only caution is getting transistors with the voltage rating.
Why are you adding a "latching" transistor circuit ahead of a "latching" SCR? If you're going to do that, drop the SCR and drive the relay with your transistor circuit?
Ken
I agree with that as well and said the same thing the first time this topic was circulating.Was just a curiosity.
I think that even though Suzukiman measured the output as 0.0-0.8V on a DVM, the output is probably (from my experience) 0v to 1.5V. What I've seen on an o-scope is a series of pulses with a very low duty cycle. A DVM averages this to a low "average" voltage. I don't think he will need to offset the alarm voltage.
But...we will see.
Ken
The relay is a 24V dc type about 2400 ohms, another one is 1200 ohms, but I have to recheck that for you again. It is going to switch a low current DC 30V.If you wanted to provide details like the relay model so that I could find a data sheet that would be help me give you more refined help. I am also wondering if it was asked or just assumed, but is the relay being used to switch AC?
The relay is a 24V dc type about 2400 Ω, another one is 1200 Ω, but I have to recheck that for you again. It is going to switch a low current DC 30V.If you wanted to provide details like the relay model so that I could find a data sheet that would be help me give you more refined help. I am also wondering if it was asked or just assumed, but is the relay being used to switch AC?
