Is it possible to connect an led in parallel with a lock mechanism?
I am working on a project. I have a keypad panel that unlocks a door and I want to add in the circuit an led indicator(when the lock is released I want the led to turn on. When connecting the lock with the led in parallel the keypad does not work properly. The lock uses 1amp and the led needs less than 350ma. Would a resistor on the led solve the problem? If yes, what resistor should I use? (it's obvious I don't know much about electronics but I wish to learn...). Any ideas or ideas or advice is most welcome! Thanks community!
