Keyboard PCB schematic check
lukxa
Joined Jan 17, 2023
13
Hello everyone, I am new to electronics and still learning. I created a simple keyboard PCB design in EasyEDA and plan to order it from JLC pcb. I would appreciate it if someone could check the design I made if there are some errors as I am new to this. I plan to make the PCB in 2 layers, so purple wires would be on the top layer of the PCB and green traces would go on the bottom layer. Thank you.
djsfantasi
Joined Apr 11, 2010
9,237
That doesn’t look like a PCB design. It looks more like a schematic. There are no pads for the switches, diodes nor the connector. The lines should not have 90° angles. You wouldn’t have the components shown on a PCB design unless they were on a silkscreen layer. Unless JLCPCB provides a design service (I don’t know if they do), they won’t be able to create a PCB from this diagram.
lukxa
Joined Jan 17, 2023
13
Hello, thank you for your reply. Sorry, I made an error writing that this is a PCB design. I meant schematics, I will be making design soon, but first I wanted to check if everything was ok.
