Jfet RF preamp construction.
0ri0n
Joined Jan 7, 2025
197
What does "zero success" mean?
A J310 or it's SMT counterpart would be more appropriate for the input stage. You don't have to actually use "faint" input signals in your simulation. Go with something like 10 mV or a similar amplitude.
What is the purpose of the second 1kHz voltage source and why is the impedance of the source only 0.2 Ohm? Selectivity is non-existant and amplifier gain is way to high for this frequency range, which only compromises even further the probably already not stellar dynamic range of the receiver.
ericgibbs
Joined Jan 29, 2010
21,651
hi Light,
The Freq source of 324.259 is not 324kHz it is 324Hz.
Increased the source amplitude to 1mV for testing the sim.
This plot is what LTSpice shows.
E
BTW: it helps if you label the Nodes of interest.
