Hi ,
Iam a beginner in electronics ,but did lot of DIY and troubleshooting in electronics with the help of internet and technical persons.
My JBL Xtreme 3 portable speaker works well with the original 20V power supply adaptor when plugged in(works well directly from the powersupply even battery is empty), but the battery is not charging with the 20v supplied charger. If I plugin to 5V mobile charger the battery is charging. After charging there is no issue in working with the battery supply until the battery die. With the 20V charger ,charging indicator is blinking but not moving on to the next charge level indicator( remains in the same charge level indication).I have attached the service manual which has the circuit diagram for the charging circuit. Kindly help me to troubleshoot the circuit
