Registered just to say - thank you! You saved the day and made this to be super easy fix!Check D8 diode on SMPS.
Quite often it gets damaged. I had a problem with it in L8 and L16.
Unfortunately there is no diagram for the power supply.
Yes, the letter after the CP is important! It's V, T or L ....OB2279CP i guess
Hello,Check D8 diode on SMPS.
Good day,Check D8 diode on SMPS.
Hey! did you ever find the fix for this i have an L8 with similar symptomsHello,
does sb know what exact part
Good day,
I also have a problem with my JBL authentics L8. It seems that the component marked D8 is faulty. On the diode it says PJ351 BR220. I have looked on the internet but have not found a replacement part with this exact designation. I have found very similar diodes under the abbreviation BR220. However, I am unsure whether I really replace the part suitable. Can you help me there?
I thank you in advance for all responses
Translated with www.DeepL.com/Translator (free version)
Regarding my L16, I am still looking for something to replace D8 with. I watched the YouTube video, but I was unable to see what the guy uses. Can anyone help please?Hey! did you ever find the fix for this i have an L8 with similar symptoms
Simulating SMPS circuit | PCB Layout , EDA & Simulations | 6 | |
| C | Piezo speaker driven by UC3845 on 30 Volts SMPS Power Supply? | General Electronics Chat | 23 | |
| E | JBL Authentics L16 | Technical Repair | 0 | |
| H | JBL Authentics L8, turns on and pairs, but no sound. | Technical Repair | 1 | |
JBL Authentics L8 SMPS .. #2 | Power Electronics | 1 |
