Registered just to say - thank you! You saved the day and made this to be super easy fix! Thank you again!Check D8 diode on SMPS.
Quite often it gets damaged. I had a problem with it in L8 and L16.
Unfortunately there is no diagram for the power supply.
Yes, the letter after the CP is important! It's V, T or L ....OB2279CP i guess
Hello,Check D8 diode on SMPS.
Good day,Check D8 diode on SMPS.
Hey! did you ever find the fix for this i have an L8 with similar symptomsHello,
does sb know what exact part
Good day,
I also have a problem with my JBL authentics L8. It seems that the component marked D8 is faulty. On the diode it says PJ351 BR220. I have looked on the internet but have not found a replacement part with this exact designation. I have found very similar diodes under the abbreviation BR220. However, I am unsure whether I really replace the part suitable. Can you help me there?
I thank you in advance for all responses
Translated with www.DeepL.com/Translator (free version)
by Robert Keim
