It's a water level switch, and I need to power a hydroponics water aerator.
mekineer
Joined Nov 23, 2021
I have a sensor switch that can only power 10 watts when switched. Where can I find a diagram of how to make the switch trigger full power in a circuit?
ElectricSpidey
Joined Dec 2, 2017
3,363
In that situation you would use a relay or transistor to switch the load, but you are going to have to give more information on the sensor, power supply, aerator...etc.
35,280
Welcome to AAC!
You can use a mechanical relay to switch higher power.
AnalogKid
Joined Aug 1, 2013
12,290
Your question is missing a lot of information.
What is "full power"?
What is the power source for the sensor?
Is the sensor output a set of relay contacts, or is it a solid-state switch such as an open collector or open drain?
What are the voltage and current requirements for the pump?
ak
