It looked like a split MOV but it's cut on purpose?
MikeA
Joined Jan 20, 2013
447
While replacing a fuse in my Fluke multi-meter I noticed a split in this little yellow 1500V MOV. I thought it exploded from over voltage at some time in its life, as I'm not the first owner. But looking more closely at the split under a microscope it looks very clearly like it was cut on purpose.
Am I correct in my observation? And if so, what's the point of cutting it like that? Is it like a pressure release valve?
MikeA
Joined Jan 20, 2013
447
I looked up the schematics and the part is called "Surge Protector 1500V +/- 20%".
So is there just a piece of wire inside the blob? And it shorts over voltage input through a spark?
ronsimpson
Joined Oct 7, 2019
4,690
Here is a Gas Discharge tube. Similar but in a tube. See the gap. Can use different types of gasses. To get low voltage they can make the ends radioactive.
MikeA
Joined Jan 20, 2013
447
My bottled water has that warning.
I bought a little bag of wooden dowels at Home Depot. It had this warning.
WARNING: Drilling, sawing, sanding or machining wood products can expose you to wood dust, a substance known to the State of California to cause cancer. Avoid inhaling wood dust or use a dust mask or other safeguards for personal protection. For more information go to www.P65Warnings.ca.gov/wood.
