Is it powered by a switch or transistor? With the switch or transistor off measure across the transistor orb switch with the amp meter.Hi
I need to measure the current through a device but cannot connect an ammeter in series with it.
Is there anyway to measure it?
Note: This will require that you clamp it around only one of the 2 power conductors.. So if its got a cord/cable with all wires bundled in it and no way to access a single cable only then you might be out of luck..Yes, look into hall effect sensors. There are commercially available clamp-on current meters.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
