I apologize if this is a duplicate, but I have looked around and what were solutions for other people's problems did not work for me.
As a part of a project, I am trying to make a 48Vdc supply that plugs into 220Vac. Instead of using a transformer I would like to design a buck converter. Here's what I came up with:
I simplified the schematic so that it does not include the rectifier, just the buck converter. Also, I separated out some parts of the circuit into subcircuits because I think it is easier to understand what's happening that way. Here are their schematics:
For the controller I chose TL494 for various reasons, the biggest one being the fact that this is new to me, and the datasheet for TL494 had a very nice Example Application section. I need to be able to simulate it because I don't really know how to select a frequency otherwise. After attempting to simulate it and getting a convergence error I turned on auto convergence and got it to simulate (graph.png) for about 100us, but any more than that gives me a overflow error. The frequency seems to be stuck at 40kHz unaffected by the values of Rt and Ct.
Here is the convergence error:
Both errors seems to happen around the time the first pulse should be happening (see graph.png). Another thing that confuses me is the 256A at V1.
I guess this is the only info it gives me for the overflow error:
Other than solving the error and understanding why I cannot change the frequency, I would like to know why there is a pulse on Vg at the very start.
If there is anything else I should post please let me know. (I can simulate the 100us and graph more things if needed)
ERROR(ORPSIM-15138): Convergence problem in transient analysis at Time = 74.46E-06.
Time step = 35.44E-21, minimum allowable step size = 1.000E-18
These supply currents failed to converge:
I(X_DualDiff_U1A.egnd) = -2.540uA \ -2.545uA
I(X_PWM_PWM1.xinsttl494.Ev103) = 1.277uA \ -10.30pA
I(V_V1) = -256.00A \ -11.72mA
I(X_DualDiff_U1A.vc) = 1.155nA \ -2.255pA
I(X_DualDiff_U1A.ve) = -972.51pA \ -94.17pA
I(X_DualDiff_U1B.vc) = -612.22nA \ 65.96nA
I(X_DualDiff_U1C.vc) = 9.086uA \ -981.73nA
I(X_PWM_PWM1.xinsttl494.VV49) = -3.815uA \ -2.000uA
These devices failed to converge:
X_DualDiff_U1A.de X_DualDiff_U1B.dc X_DualDiff_U1C.dc M_M
X_PWM_PWM1.xinsttl494.X_U3.X1.Q1 X_PWM_PWM1.xinsttl494.X_U3.X2.Q1
INTERNAL ERROR -- Overflow, Convert
ABORTING SIMULATION
ABORTING SIMULATION
