ISS tracker project code help
lyxm8d
Joined Sep 10, 2022
I'm trying to do the following project:
https://www.instructables.com/International-Space-Station-TrackerPointer/
I've followed all of the instructions, connected all the components, and uploaded the code to the board (changing everything mentioned in the instructions). For some reason, I can't get it to work; neither the DC motor nor the servo motor are moving at all when I connect the battery. I asked someone to help me cut the trace and solder it so the nucleo board could work at 5v (someone who is much more experienced than me, and who checked it to make sure it was still working afterwards), so I know that isn't the problem. I have very little coding experience, so I'm unsure whether or not that's what I need to change.
Here's a picture of what I've set up:
And here's what it's supposed to look like:
Does anyone have any idea what I need to change to get the servo and DC motors to work as they should?
LesJones
Joined Jan 8, 2017
4,543
I suspect that the tiny 9 volt battery in the picture cannot supply enough current to drive the motors. Monitor the battery voltage and note how much it drops when trying to run the motors. (The link in your post states that a 9 volt supply that is capable of supplying at least 1 amp is required. The battery you are using will not supply that much current. The motor that you are calling a DC motor is a stepper motor.
Les.
lyxm8d
Joined Sep 10, 2022
Les.
Thank you for your help! I'll try a different power source when I next have access to a lab.
I did know it's called a stepper motor- I'm not sure why I called it a DC motor, but thank you.
