I'm attempting the following project:
https://create.arduino.cc/projecthu...ime-satellite-orbit-follower-tracker-w-5ef735
I've connected everything up properly, all of the components are working. I've uploaded the code to the arduino uno, changing what I think needs to be changed, but the red LED (meaning the ISS is out of range) is on constantly, even when I've changed the current time in the code to when the ISS should be overhead.
I don't have much experience with coding so I'm not sure if there's something I've missed or something else I need to add. I think it's possibly a problem with the integers epos and apos being set to equal zero, as this is what causes the red LED to turn on. This is the code I used (with the changes I've made):
Is there a specific reason why it isn't working? Is there anything I should've changed with the code?
Any help would be appreciated
Moderators note : added code tags
Code:
#include <TimeLib.h>
#include <ArduinoP13.h>
#include <Servo.h>
Servo elevation;
Servo azimuth;
// Current UTC [NOT LOCAL TIME]
int CurrentHour = 20;
int CurrentMin = 20;
int CurrentSec = 00;
int CurrentDay = 22;
int CurrentMonth = 9;
int CurrentYear = 2022;
// Set TLEs of your desired Satellite
const char *tleName = "ISS";
const char *tlel1 = "1 25544U 98067A 22264.34024677 .00027245 00000+0 48016-3 0 9990";
const char *tlel2 = "2 25544 51.6428 220.2201 0002499 280.2153 244.2840 15.50209155360097";
// Set your Callsign and current location details
const char *pcMyName = "S21TO"; // Observer name
double dMyLAT = +53.415150; // Latitude (Breitengrad): N -> +, S -> -
double dMyLON = -2.917480; // Longitude (Längengrad): E -> +, W -> -
double dMyALT = 67; // Altitude ASL (m)
int rangePin = 7; // LED for in Range Indication
int NrangePin = 6; // LED pin for Out of range indication
int epos = 0;
int apos = 0;
double dSatLAT = 0; // Satellite latitude
double dSatLON = 0; // Satellite longitude
double dSatAZ = 0; // Satellite azimuth
double dSatEL = 0; // Satellite elevation
char acBuffer[20]; // Buffer for ASCII time
void setup()
setTime(CurrentHour,CurrentMin,CurrentSec,CurrentDay,CurrentMonth,CurrentYear);
elevation.attach(9);
azimuth.attach(10);
elevation.write(epos);
azimuth.write(apos);
pinMode(NrangePin, OUTPUT);
pinMode(rangePin, OUTPUT);
Serial.begin(9600);
delay(10);
digitalWrite(NrangePin, HIGH);
digitalWrite(rangePin, HIGH);
delay(5000);
void loop()
char buf[80];
int i;
int iYear = year(2022); // Set start year
int iMonth = month(9); // Set start month
int iDay = day(22); // Set start day
int iHour = hour(14); // Set start hour [ substract -6 from current time ]
int iMinute = minute(20); // Set start minute
int iSecond = second(0); // Set start second
P13Sun Sun; // Create object for the sun
P13DateTime MyTime(iYear, iMonth, iDay, iHour, iMinute, iSecond); // Set start time for the prediction
P13Observer MyQTH(pcMyName, dMyLAT, dMyLON, dMyALT); // Set observer coordinates
P13Satellite MySAT(tleName, tlel1, tlel2); // Create ISS data from TLE
MyTime.ascii(acBuffer); // Get time for prediction as ASCII string
MySAT.predict(MyTime); // Predict ISS for specific time
MySAT.latlon(dSatLAT, dSatLON); // Get the rectangular coordinates
MySAT.elaz(MyQTH, dSatEL, dSatAZ); // Get azimut and elevation for MyQTH
Serial.print("Azimuth: ");
Serial.println(dSatAZ,2);
Serial.print("Elevation: ");
Serial.println(dSatEL,2);
Serial.println("");
delay(500);
// Servo calculation
epos = (int)dSatEL;
apos = (int)dSatAZ;
if (epos < 0) {
digitalWrite(rangePin, LOW);
} else {
digitalWrite(NrangePin, LOW);
if(apos < 180) {
apos = abs(180 - (apos));
epos = 180-epos;
} else {
apos = (360-apos);
epos = epos;
delay(15);
