I guess at this stage, the discussion has gone beyond off topic. IMHO, the answers seems to be pretty conservative and cautious; many alternatives were suggested. May be its due to the nature and the risk associated with lightning and naturally being cautious of it.
So,it was implied that if the power supply wires are going towards the sky, (rather beyond a critical elevation, that might depend on the location and features), then a Faraday cage, and a lightning arrester are needed. As advised by MrChips,
But if the device is at a lower height, just as tall as a roof top of a house,(say that has a very low probability of getting hit by a lightening), yet, it seems to be at a probable risk because I am putting up a conductor. Now I think of how lucky was Benjamin Franklin to fly that kite.You need:
1. A lightning rod.
2. Power cable inside rigid metal conduit.
3. Faraday cage around your device.
So I guess, however small, simple and low budget the project may be, we have to respect Mother nature.Hmmmmm....given that some scientists shoot rockets into thunder clouds to cause lightning discharges that then follow the wire down to the ground, the answer is "probably".
IMO the best solution will be to place the battery with the device itself and then use a solar cell to keep the battery charged... OK now I have to climb up to the water tank back. Oh by the way, how about a method of intermittent charging of the battery from ground level. When there are not storms I can charge the batteries and then roll up the wires. Will there be sparks from the wire ends? Do I have to maintain a minimum gap from the wire ends?You could try a solar panel and battery powered sensor and a radio link.
