I'm having a problem with an isolated half bridge driver circuit where the gate driver keeps failing.
I'm trying to use two "Si8261BBC-C-IP" isolated gate driver ICs to isolate the MCU from the MOSFETs, but it keeps failing after less than 1 minute. As soon as I replace the component with a "FOD3180TV", the circuit works for more than one hour.
At this stage I'm using a resistor as a load in my test circuit which is running at about 50-kHz and a 40 % duty cycle.
I would really like to have someone just look at my circuit diagram and make a suggestion as to what might be wrong or what I might improve on. The problem is that the gate driver keeps failing and I just simply cannot understand why and what is wrong. The output of the circuit (as measured on an oscilloscope) seems to be a perfect square wave.
Any advice would be greatly appreciated.
Kind Regards
Kind Regards
