Isolated circuit output
pinkyponky
Joined Nov 28, 2019
351
I have chosen the component (LP2748 is attached) for isolate the signal between the two circuits.
If I apply 24V to pin1 and 5V to pin6, then what is the value at pin5 (Vo)?.
If I apply 0V to pin1 and 5V to pin6, then what is the value at pin5 (Vo)?.
Do we need to use any resistors to pin1 and pin5?. If so, what values need to be used?.
click_here
Joined Sep 22, 2020
548
"I_f" on is recommended to be between 2mA and 10mA, so you'll need to put a resistor in series with that
24V/2mA = 12k
24V/10mA = 2k4
I'd probably use an 8k2 because it is close to the testing conditions that they use (3mA) - But you'll also need to check the thing driving this can provide 3mA.
You also want to minimise output current to 2.1mA, but you need to look at the load to see if that needs a resistor...
You will need a 100nF bypass resistor between pins 6 and 4
34,047
Definitely for pin 1 otherwise you let out the magic smoke.
The normal input diode current should be from 2ma to 10mA.
For a nominal 5mA with a 24Vdc input and a 1.5V nominal diode voltage, you should put about a 4.5kΩ in series between the +24Vdc and pin 1.
Pin 5 needs no resistor unless the load on that pin would draw more than 50mA.
Note that for true isolation, the ground for the 24Vdc cannot be common with the ground for the 5Vdc, otherwise you defeat the purpose of the isolator.
pinkyponky
Joined Nov 28, 2019
351
What will be the output if I apply 24V or 0V?
Is it necessary to apply the 5V to pin6?, because, some of the tutorials saying that the pin6 left floating.
pinkyponky
Joined Nov 28, 2019
351
What will be the output of "Optoisolators - Transistor, Photovoltaic Output" and "Optoisolators - Logic Output"?. As I said I will apply 24V or 0V to the optocoupler (using for control the power supplies), so which type of optocoupler is correct for this application?.
click_here
Joined Sep 22, 2020
548
The input is *current*, not voltage
The graph that I shared shows the input current vs Vout
The current you supply is determined by a series resistor.
pinkyponky
Joined Nov 28, 2019
351
In general, for example, If we apply 2mA current to the LED. Then, does we will get the same amount of current (2mA) at the collector of photo transistor?. Or Is there any current will lose?.
click_here
Joined Sep 22, 2020
548
In an optocoupler with a transistor output, current gain has to do with the CTR.
Here is a great explanation http://electronicsbeliever.com/opto-coupler-ctr-explanation/
If you want to check any particular device for what the CTR at a particular I_f is, the datasheet tells you.
All that said: This doesn't apply to the device you are using. The TLP2748 is specified in I_f vs
V_out, not CTR (current in vs out).
