Is this original or fake transistor
dl324
Joined Mar 30, 2015
18,476
Is this TIP3055 original or fake?
Your pictures don't have enough resolution to see if any of the counterfeiting telltales are present. My suggestion is to test for beta and maximum current to see if they're within specifications.
If you use a PWM circuit to test maximum current you can reduce power dissipation, and therefore heat sinking requirements.
A curve tracer would make checking beta more convenient.
Ian0
Joined Aug 7, 2020
13,287
Isn’t a 2N3055 chip the sort of thing you might use to fake something better if you were in the business of making fake transistors?
