I have a microprocessor controlled radio project that needs a brownout detector so I can save the Band and Frequency information into EEPROM when the power is turned off or fails. The power supply is 18VDC and the microprocessor runs on 5V with 3.3V I/O levels. What I need is a detector that will send a high (+3.3) signal to the microprocessor when the 18V supply falls below about 13V-14V so it will have enough time to save the information.
The attached schematic is my attempt to make that detector. Will this work as described?
