can someone help me fix this problem cause this thing has going for on weeks and somehow i still can create and schematic on this one
kurokoko
Joined Apr 7, 2025
11
Design a circuit that utilizes an SCR and and an LDR, along with the necessary components, to reverse the rotation of a DC motor when a shadow is detected. What i meant is cant*
Alec_t
Joined Sep 17, 2013
15,171
Please post your best effort at doing this assignment, so that guidance can be given where necessary. We do not do assignments for you.
kurokoko
Joined Apr 7, 2025
11
the problem is i need the ldr to be 0 ohms and ldr cant be 0 ohms its so impossible and also were not allowed to used relay so were having a hard time to get it.
MaxHeadRoom
Joined Jul 18, 2013
30,885
Also in a practical circuit sense, there could be an issue of using immediate reversal ?
A use of a simple comparator could be used to ensure off when at a shadow is detected.
MaxHeadRoom
Joined Jul 18, 2013
30,885
yup were limit on using components on this assignent this is the closer i can get i also think this only works in simulation not in practical real experiment
In the real world, it is not always practical or safe in regards to such as motor-mechanism's etc, to do an instant motor reversal,
In practice, either a small delay is used to allow the motor to stop before reversing, or a ramp up at start can be used .
panic mode
Joined Oct 10, 2011
5,480
DC motor should be fine with DC, regardless if the DC is steady or pulsed. if that was not the case PWM would not work to control motor speed.
i have no idea what the transistors in the circuit are meant to do and hope TS can elaborate. for now i removed them and annotated parts so one can have a discussion.
TS thinks that SCR is a rectifier... and rectifiers pass current in one direction. so what is the point in having both SCR1 and SCR2 connected in same directions - if working as rectifiers and triggered by LDR, both will pass current in the same direction.
then what is the reason for D1 since it is in same direction as SCR1?
and what is the reason for D2 since it is wired in opposite direction of SCR2?
WBahn
Joined Mar 31, 2012
33,357
What are the "necessary components" allowed to be?
Break the problem down into smaller pieces. Forget the motor for now. Can you make a circuit that produces a low voltage when there's a shadow and a high voltage when there isn't (or the other way around)?
