Is this Foot Switch Relay useable with DC?
Alec_t
Joined Sep 17, 2013
15,171
It will work ok with low-voltage low-current DC initially but, depending on the contact material, the contacts may go high resistance in time. In normal AC high-voltage use there is enough current to keep the contacts 'wet'.
28,643
Indeed the switch can be used for DC, and as stated, you may at some point suffer from some contact resistance problem. Ot maybe not, depending on the mechanical operation of the switch.
