Yes.Would the circuit work with 18 volts instead of 16?
But it will increase the power dissipated in the LM317 for a given charge current.
No.Would it need the current limiting resistor to be more resistive?
The current limit is determined by the Vbe of Q1 and is not affected by the supply voltage.
Yes to all.Would it be ok to substitute 220 and 2200 respectively? Is it also ok to replace R5 with a 2200 ohm resistor?
Yes.Could I substitute the op amp with an LM358?
That opamp can be substituted for the comparator.
