panic mode
- Joined Oct 10, 2011
- 5,251
i think there was an interesting resistor with pretty unique markings. not sure if it was measured or replaced. it was stated that it was damaged somehow nut it is not clear in what way (open, short, intermittent). most resistors fail open. in that case it did fail open, one can try removing coating to expose resistive element. then one can try measuring resistance of whatever remained and extrapolate actual value. maybe the resistive element is intact and fusible element failed. whatever the story, 20 posts later i was hoping to see more about it.
