Is there any technique in which I can send 433MHz and 915 MHz with the same antenna?
ashokraj
Joined Feb 1, 2018
151
I am using LORA. Is there any multiband antenna that can support these two frequencies?
or
I would need an antenna with the same footprint for 915MHz and 433MHz. Technically, as the frequency reduces antenna length increases. I am wondering with advancements in technology if at all there is some component that can solve my problem.
Thanks,
Ashok
Ya’akov
Joined Jan 27, 2019
10,233
Dual, tri, and even quad band antennas are common. There are a number of design strategies depending on the form factor of the antenna. You can find a lot of information by searching for “dual band antenna design” and adding the bands of interest will help, though in those IoT focused bands you will find a lot of microstrip and PCB antennas e which may not be what you are in interested in.
Mobile ham radio operators have a special interest in multiband antennas and particularly common are 2m/70cm (144MHz/440Mhz) models. You might find information about practical construction from that source. The will be of the monopole variety.
As @dendad points out, you will need diplexer circuitry at the end of the feedline to connect the two transceivers. At the low powers used in those bands, it can be on the PCB. His suggestion of a discone, which is an inherently wideband design is certainly reasonable but for the likely application you have in mind some collinear design is more likely to be the best choice.
So, yes, dual band antennas are certainly possible, and are quite widely used. The exact physical realization depends on the type of antenna you need.
UweX
Joined Sep 2, 2020
35
I recommend to take a look at https://www.diamondantenna.net . As a ham I am using an antenna for 144/43/1200 MHz (2m/70cm/23cm). That are only the frequencies, where operation (SWR) is specified. I attached a transceiver also able to receive FM-radio and the signal from the antenna was strong enough to generate intermodulation in the handheld transceiver. So besides frequency of operation the aspect of size, ruggedness and withstanding outside weather conditions maybe more important. So I recommend to try out a ham-band antenna covering 70 cm ( exactly 433 MHz) and 23 cm ( 1.2 GHz, but not too far away from 915 MHz). I expect the transmitter you are using low power, so getting some reflection from the antenna at 915 MHz may not burn the output.
In case you need some directivity look at a logarithmic periodic antenna (LPA). These cover usually a broad frequency range. Here 433 MHz maybe a little bit too large for a PCB-style antenna, but there are also a lot of different construction advice around.
Tim-MK
Joined Oct 29, 2019
7
I am using LORA. Is there any multiband antenna… with the same footprint for 915MHz and 433MHz.
I would assume you are shipping to different countries and their unlicensed bands differ?
… might be facing the same dilemma myself in the near future…. As RF manufacturing depends on critical tuning to get optimum performance I would approach it by using similar modules targeting each countries RF band.
as a licensed Ham (some years ago now) the antenna tuning is foremost in achieving the range.
luclussier
Joined Jul 10, 2023
or
Thanks,
Ashok
I have been using the Linx mini patch antenna , same form factor for both 433 and 915 MHz bands.
Easy to use and low cost.
433MHz: ANT-433-USP410
915MHz: ANT-915-USP410
Available from Digikey
Luc Lussier
IoT system and component engineer
Nordicom Inc.
sagor
Joined Mar 10, 2019
1,049
Depending on size and gain, you could look into log periodic antennas. They are designed to cover a wide range of frequencies. They are also directional, so if you want omnidirectional, the discone would be the option to look at.
Ya’akov
Joined Jan 27, 2019
10,233
Nothing wrong with a log periodic, or discone*—but the TS is working with LoRa. This suggests he needs a low profile antenna.
One confusing thing is that places where LoRa may legally operate on 433MHz, it may not operate on 915MHz—and vice versa. So it is hard to understand why he would need a dual band antenna.
*Except that TS has two narrow bands of operation and the strength of these two designs is board coverage. It would be better to have a collinear dual-band design which would exhibit more gain and better front-to-back ratio for the same size boom.
