MaxHeadRoom
- Joined Jul 18, 2013
- 30,885
There is also the 3M reflective tape, I was thinking the glitter paint may replicate this?Hello,
I wonder if the glitter would scatter the light from the sensor to much.
Bertus
Max.
Bertus
Another good possible. I have used the AIRPAX Magnetic sensors on numerous systems. They are good for picking up teeth on a gear and should work fine for the above task.One other route is to use a ferrous detect (non-magnetic) style proximity sensor on the spokes.
Max.
The reason that I suggested half the wheel is that at higher speeds the pulse may be too short for some counter circuits. Since paint is both cheap and easy, the 50% coverage would produce closer to a square wave and be more reliable. Admittedly this is a bit more than a perfect counter needs, but a very easy way to reduce the possibility of a problem. At the time I posted that suggestion I had no idea what the application was, and some applications include very fast motor speeds.One other consideration on the resolution is if it is just for RPM monitoring/indication or RPM control is considered, if the latter, then closer control is achieved using a multi count/rev method.
If using a one/turn retro-reflector, use a single small white paint stripe or tape, not half the wheel.
Also I have tested the QRE1113 I used for any effect of incidental light that might be present, but I did not detect any detrimental effect from the sources I used.
Max.
I have quite a few 12mm dia in my surplus stash, Baluff, Turk etc.Another good possible. I have used the AIRPAX Magnetic sensors on numerous systems. They are good for picking up teeth on a gear and should work fine for the above task.
Ron
I have one of those from one of my old trucks. It was never quite the same after working its way into a gear.I have quite a few 12mm dia in my surplus stash, Baluff, Turk etc.
Also another source is an auto wrecker for the Honeywell 1GT101DC gear timing detector.
Max.
The application of reflective patches looks reasonable, but it may be that the shiny black paint also reflects light. Only testing will determine that. And it might possibly be that it works perfectly up to some speed. You do need to be certain that the mount for the sensor is stable and rigid.What do you think of this? Is it correct? I will use this reflective sensor. Another info is that the motor will be enclosed, so ambient light should not disturb. I haven't tested it yet.
I wondered myself about that shiny black. I was not sure if it could cause issues.The application of reflective patches looks reasonable, but it may be that the shiny black paint also reflects light.
You will know when you test it. I have used a piece of reflective tape doing test on some shiny stainless steel shafts and it worked. I guess it all comes down to testing it.I wondered myself about that shiny black. I was not sure if it could cause issues.
