PNP?For example, A NPN BJT switch is open when the base collector voltage is too low, but is there an transistor where the switch is closed when the transistor is off and open when voltage is high? Thanks.
NJFETs also are on when Vgs=0.You might look at depletion mode MOSFETs. Depending on exactly what you are doing, a PFET might also work.
