Is there a dual trimmer or small potentiometer?
Carlos Martínez 1
Joined Nov 23, 2016
32
I have trimmers 3296 and 3006P, but i need to vary at the same time two resistors(from 10 Ohm to 10kOhm). is there any kind of trimmer(a conventional potentiometer is too big) that I can use?
Could I make one by myself at home? How?
GopherT
Joined Nov 23, 2012
8,009
What does your circuit look like? Maybe there is another solution other than a matched potentiometer / trimmer. I assume there is another (easier/cheaper) solution because it is unlikely you are the first person to have this problem - and yet, the suppliers don't offer a solution.
spinnaker
Joined Oct 29, 2009
7,830
There has to be a reason they are not readily available. My guess is trimmers are too fragile for dual gang.
Here is a pot that is only 12mm
http://www.alps.com/prod/info/E/HTML/Potentiometer/RotaryPotentiometers/RK09L/RK09L12D0A1W.html
Looks like this one only 8.8 mm
http://www.mouser.com/ProductDetail/ALPS/RK08H122005A/?qs=sGAEpiMZZMtC25l1F4XBU3JeeCo7XMTl55QAFLjxm2c=
Did not check the values and maybe these not small enough. But at least you know small dual gang pots exist.
You could try gluing a couple of this type together.
http://www.mouser.com/ProductDetail/Bourns/3352T-1-103LF/?qs=sGAEpiMZZMvygUB3GLcD7rufck0TIBKy5gx03CoSSR0=
Alec_t
Joined Sep 17, 2013
15,171
There are SMD trimmers available which are adjustable from the top and bottom. Perhaps you could stack two of those and use a common adjustment shaft?
atferrari
Joined Jan 6, 2004
5,032
I recall dual presets in old TVs that I disassembled many years ago. Still there should be one around somewhere. Bulky to say the least.
Now, two matched pots means two equal voltages going to two different points in the circuit.
I believe is the same as generating just one voltage and solving how to deliver it to those two points. Unity gain buffers with a dual op amp into play?
GopherT
Joined Nov 23, 2012
8,009
I'm just saying it would be nice to see the OP's circuit - there are options to supply the same voltage or current to two different circuits without a ganged dual trimmer. A small SOIC dual op amp can do this with one POT, for example...
shortbus
Joined Sep 30, 2009
10,049
And trimmers while a type of potentiometer are not to be used as a pot. They are meant to just 'fine tune' in a circuit, a set and forget if you will. They aren't robust enough for normal pot use.
EM Fields
Joined Jun 8, 2016
578
Not necessarily, since two matched pots can have different end-to-end voltages.
ian field
Joined Oct 27, 2012
6,536
Most dual gang pots are logarithmic for stereo audio volume controls.
There used to be stackable preset pots - but they've become much harder to find since they've been designed out and replaced by settings in NVRAM configuration chips.
EM Fields
Joined Jun 8, 2016
578
Then why to have them ganged?
If one voltage has to be proportional to the other, op amp A is unitty gain buffer and B a multiplier. Still just one preset.
Not one "preset", whatever that's supposed to mean, but one shaft driving both pots or one pot driving both opamps, which is nothing like what you proposed initially.
