Is there a component that is the reverse of a line decoder?
richard3194
Joined Oct 18, 2011
193
Hi. A line decoder accepts binary input (like say from an address bus) and one of the available output pins will be set to high.
Alright, but is there an IC that works in the reverse? One where if you place a logical high on a particular pin of the several available, will produce a binary number output? Thanks.
danadak
Joined Mar 10, 2018
4,057
Or a demux, this example 4 control inputs decode into 1/16 outputs.
An analog mux operated inverse also can do this.
Regards, Dana.
danadak
Joined Mar 10, 2018
4,057
I stand corrected. Mux inappropriate.
ROM or LUT the way to go. LUT has advantage could be synchronous, so
glitch free outputs. ROM with clocking also could be synch.
Regards, Dana.
38,686
Also a priority encoder as Les suggested.
For example the CD4532 generates a 3-bit output as determined by which of its 8 inputs is high, and can be expanded to handle any number of inputs.
